0 members (), 116 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1032273 05/30/2014 3:25 PM
If the wires were hooked on the back of the fuel gauge incorrectly will that ruin it? I installed a new sending unit. I have one wire hooked to the back of the gauge frome the ignition switch and the other terminal on the gauge has the wire from the sending unit connected to it, the tank is full but does not register on the gauge. Where did I go wrong?
jdchevy #1032287 05/30/2014 5:53 PM
jdchevy #1032288 05/30/2014 5:56 PM
I believe originally there was a red warning tag attached to the sender post.
Stating not to apply power to that post
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=849376
On the AD trucks there is a paper divider that goes between the post on the back of the gauge
Moderated by  ndkid275, Phak1
