| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | There are two holes low just above the oil pan on the passenger side which go all the way through to the crankcase. they are for holding the sheet metal piece with a sort of filter which is where the draft tube comes out. If you don't put bolts back in it will leak while the engine is running and drive you crazy looking for a leak. Larry
58 gmc 100 with 350 sbc
