8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC),
104
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | Readjust the choke as follows. With the ambient temperature at 68 degrees F. (65~70 is close enough); depress the throttle to wide open and release (this releases the choke lockout); with one hand hold the throttle about half open; with the other hand slowly rotate the choke cap until the choke butterfly starts to close, and continue to rotate until the choke butterfly just touches closed; release the throttle, and tighten the choke cap retainer screws. This procedure will adjust the choke to standard setting.
It is possible that depressing the throttle to wide open will close the choke valve.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
