Up to the Carb. From tank to pump, from pump to carb. Use a filter.
Wire from ignition switch to run the pump. You will need to make a block to cover the place the old pump was living in. Keeps the oil in and the dirt out. I would run the fuel line like the original as much as I could.
Steve H
