2 members (RayF, MNSmith),
154
Mod | | | Forums66 Topics128,284 Posts1,058,528 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10256 03/15/2005 9:54 PM | Joined: Feb 2004 Posts: 29,953 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,953 | Yes, it's fairly common for a timing gear to fail, but the cam usually quits turning when it does. A couple of teeth will strip on the fiber gear, and the crankshaft turns, but not the cam. Here's a quick way to check the cam timing:
Remove the valve cover, and pull the spark plugs. Watch the #6 cylinder valves. Turn the engine with the fan until the exhaust valve starts closing. Keep turning the engine over until the #6 intake valve starts to open. The #6 piston should be at top dead center on the exhaust stroke, and the #1 cylinder will be on TDC on compression, with the distributor pointed to the #1 plug wire, and the points just barely open. Any other relationship between the valves and pistons indicates a jumped/stripped timing system, either chain or gears. This works on all engines with an even number of cylinders, just use the cylinder halfway down the firing order from #1.
Inline 6: 1 5 3 6 2 4, companion cylinders that come to the top together are 1&6, 2&5, and 3&4.
V-8: 1 8 4 3 6 5 7 2, companion cylinders are 1&6, 8&5, 4&7, and 3&2. Works every time! Jerry
Entire Thread
235, 62 1/2 Ton, Pulling oil Pan?
| gtex | 03/15/2005 9:29 PM |
Re: 235, 62 1/2 Ton, Pulling oil Pan?
| 8trackdude | 03/15/2005 9:43 PM |
| Hotrod Lincoln | 03/15/2005 9:54 PM |
| gtex | 03/16/2005 3:57 PM |
| Fred T | 03/16/2005 5:56 PM |
| 8trackdude | 03/16/2005 7:18 PM |
| Fred T | 03/16/2005 8:58 PM | |
