So the other day my '42 panel had a mishap. A friend opened the locking door with the key (both original) and the key cylinder fell out with the key. Seems as though the key cylinder slides into/attaches at the rear to the shaft that goes through the handle. It sheared off. I can't find supplier for the shaft replacement. Worst case scenario I replace the whole locking handle but can't come up with that source either. Any sources out there?
