| | | Forums66 Topics128,134 Posts1,056,401 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It should come on when the knob is turned to the left, and there should be a stop when it reaches the cntacts to turn it on. Sounds like there's something afoul in the switch itself, perhaps the tab that the shaft engages into is stripped out, not allowing it to turn with the shaft. Does the dimmer part work ok?
Bill Burmeister | | |
