| | | Forums66 Topics128,192 Posts1,057,350 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Bar Keepers Friend contains (unless they've changed it recently) oxalic acid which is sometimes used for removing rust stains. To effectively remove rust I think you would have to add extra water instead of the normal way of using it as an abrasive polish.
Harold Wilson 41 Chevy 3/4 Ton
