| | | Forums66 Topics128,195 Posts1,057,372 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Anybody ever used Bar Keepers Friend to remove rust ???? How doe's it work ????
" STUCK IN THE '50'S "
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have used it to clean and polish stainless steel. It is excellent for that. They say it is also good for rust removal. My guess is that they are referring to surface rust - not deeply pitted rusted surfaces. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Never heard of it before. Learned something new today.
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I've heard it was great on stainless steel , I'll try it this week , I have a '50 coupe being shipped , should be here Thursday The molding is all there but off the car , and from the pics. needs a lot of attention .
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Bar Keepers Friend contains (unless they've changed it recently) oxalic acid which is sometimes used for removing rust stains. To effectively remove rust I think you would have to add extra water instead of the normal way of using it as an abrasive polish.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | "On metal, porcelain, plastic and fiberglass the surface should be wet before applying Bar Keepers Friend powder cleanser.
"For difficult stains, apply Bar Keepers Friend liquid or make a paste with Bar Keepers Friend powder and let it remain on the surface but for no longer than one minute. Rub gently as needed, rinse thoroughly."
