| | | Forums66 Topics128,086 Posts1,056,331 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,825 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,825 | The 292's should be a direct swap on the manifolds, with the possibility of a mismatch of the exhaust pipe flanges. Some of the bigger ones used a 3-bolt exhaust flange and a bigger diameter exhaust pipe, but if they're both C-60's that shouldn't be a problem. The 230 intake/exhaust assembly will probably bolt on, but there will be carburetor, and possibly exhaust pipe differences to deal with. Good luck! Jerry
