Just to make things more confusing. The park lights are off when the head lights are on. Power from the brake light switch runs the turn signals. So that must be run before the switch to the turn signal unit. Head light power goes from the head light switch to the dimmer switch. Then to the head lights. This can all be tested with an Ohm meter.
