| | | Forums66 Topics128,146 Posts1,056,795 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Is the stud short? Or are the threads damaged? You cab replace the stud..it will be slightly less difficult than one on the exhaust side. Or, you could chase the threads with a die, to clean them up. Sounds like the studs have broken off and need to be replaced.
Steve H
