| | | Forums66 Topics128,010 Posts1,055,298 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I am replacing the 6.70-15 tires on the original rims I had powder coated on my 56 Chevy 3100 stepside truck. It has the original 235 engine and the original 3.90:1 rear end. I replaced the transmission with a t5 5 speed #1352-145 from a 85-86 S10 ¹st gear is 3.76 and 5th gear is 0.72. There is no front end modifications i have the original straight axel.
What tires should I run for doing light freeway driving with the occasional trip and mostly in town putting around. I want to be kind with the rpm's and do not want to have problems with the wheel wells.
So what are your thoughts? For nows I am looking for a size that fits and works ok on that rim. Later i plan to put on a set of thick white walls but want to try a cheaper tire first before I invest in the cokers.
Thanks
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | |
