I have a 1965 Chevy C-10 which has the 0-30 ohm fuel gauge. I am looking to move the tank from the rear of the seat to saddle tanks, but am having trouble finding the correct sending unit for the tanks I've located... sending units are 5 screw hold down, tanks are lock ring.
My question, if I find a gas gauge out of a 1966 Chevy C-10, I'm guessing that it should be the 0-90 ohm gauge and I can use a more modern sending unit that is held in place with a locking ring? Does this sound correct? Just want to verify that 1966 gas gauges are 0-90 ohm. The one I've found is an AC Delco 5644735 part number.
Thanks.
Lee
