1 members (Otto Skorzeny),
181
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,934 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | | Joined: Dec 2021 Posts: 105 'Bolter | 1955.1 3100 Barn Find This truck was in a barn in Oregon for 30 years. The last owner discovered and revived it to running condition. Being a Ford guy, he turned it over to me.
So far, I have given it full factory option turn signals and side mirrors. I've found a set of original 16 inch wheels and had them powder coated. New 215/85/16 tires as well.
I'm swapping the 3 speed for a T5, currently.
In the future, I plan to add dual carbs and dual exhausts to the 235 engine.
| | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | What an amazing find.  Not very many are discovered to be as straight and solid as yours. Congratulation's, and thank you for sharing your truck with us. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Feb 2021 Posts: 156 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 156 | Nice truck. I have a couple questions. Mine came with the mouse ear turn signals on the front fenders but no turn signal switch on the column. Where did you find the turn signal switch? I noticed that you have the rear left fender with indent for spare tire. Are you keeping it that way or spare under bed? I need a fender like that if you are converting.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system. JB Weld..."I put that stuff on everything"
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Turn signals were a 54-55 factory option. Uses the same parts from a car. Today you can purchase a new reproduction.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Dec 2021 Posts: 105 'Bolter | | 'Bolter Joined: Dec 2021 Posts: 105 | Hi Joe. I recently swapped my dimpled rear fender for a no-dimple. For a spare, I use my AAA card. Buoymaker is right, factory turn signals were an option, so I bought a repro factory setup from Classic Parts and am very happy with it. It installed easily onto the column (as in photo), and lines up with the wheel nicely. New photos coming. | | |
