4 members (Donf, jay d, 46 Texaco, 1 invisible),
114
Mod | | | Forums66 Topics128,115 Posts1,056,633 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | 1959 Chevrolet Viking 40 Rich Winter Janesville, MN
I was approached this last fall (2020) and asked if I might be interested in this truck. It was located about 5 miles from my place. I had seen it in the past and it always appeared to be in fairly decent shape so I went to check it out. It was in a shed and had not been used since 2014, as their farming operation outgrew it. At some point the fellow's dad had replaced the original 6 cylinder engine with a 283 V8. The cab is in remarkably good shape for its age--a couple of small rust areas, but I've seen much worse on trucks of this age. It has 19.5" tires with the 5 and 10 lug bolt pattern. We agreed on a price and my wife and I towed it home with our pickup. There were no brakes on it so I rode the hand brake as necessary. After getting it home it didn't take too much to get it running. Mostly a matter of cleaning the points, freeing up the linkage for the manual choke which had rusted, and putting some fresh gas in the tank. So far that's about all I've done with it. It needs a new water pump, plus getting the brakes fixed, and a few other things. These will be addressed when the weather improves next spring, along with a good clean up.
| | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | Nice Viking Rich, yours is in way better shape than mine. Looks like yours has a dump bed as well.
Thanks for posting.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | Yes, it does have the dump bed. Have not tried that yet, as the cable which engages the PTO is also rusted up and not moving--something else I need to take care of when the weather warms up! | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | Got the cable freed up. The hoist works great! Fuel pump, water pump and exhaust system have all been replaced, plus extensive work done on the brakes. Currently have the generator off getting rebuilt. I also re-did the tail lights and rear turn signals so everything is now working as it should back there. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | Had some more brake work done. Also had the transmission replaced with one from a donor truck. Some of this was discussed in the Big Bolts forum. Also had the seats reupholstered, but they won't get installed till next spring. | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | I added a couple photos to the original post. Got the new seat installed. also removed the grain sides from the bed and replaced them with 12" sideboards. | | | | | Joined: Mar 2007 Posts: 3,430 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,430 | Rich, After loading the side boards that came with my truck I fully intend to do as you have and build my own.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | I hear ya! Those things are not light! I had to get help to carry them inside. I did keep them though, in case I or someone else ever wants to convert it back to a grain hauler. | | |
