1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
Hi, got the manifolds replaced using the Fenton intake and the original exhaust manifold.
all bolted up nicely. The rear Weber carb will not mount with the left firewall to fender brace bolted up. Do you guys extend, bend and lengthen that brace? It won,t take much.
Thanks Sharon
I have run without the braces without issue but plan to change that. I have seen them bent, cut and curved pieces put in, and have even heard that switching them from side to side give the clearance needed. Apparently, one is shorter than the other and mounts to a different set of inner fender bolts.
ODSS President
ODSS President
~ Cosmo
1949 Chevy Half Ton
Cosmo -
That is too cool!
- Lonnie
- Lonnie
My '54 3104
ODSS Lawman
ODSS Lawman
The horseshoe trick is as classic as the truck's owner.
chug
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Well I did Cosmo's horse shoe trick. Works pretty sweet. Thanks guys.
Sharon
