6 members (Otto Skorzeny, TexasJim50, joe apple, RaNfLaS, Hotrod Lincoln, Wayne67vert), 127 guests, and 4 robots.
Topics128,162
Posts1,057,065
Members48,463
#961250 08/05/2013 12:09 AM
Can some one post a pic of the emergency brake control rod. I need a pic of the whole linkage took it off to paint the frame now forgot how it goes back together a pic would help thanks guys
What year and size truck?
Sorry its a 1951 3100
Somebody anybody???
have checked the shop manual brake section?
Yes sir went thru and could not find a pic of how it goes together.
Check illustrations on:
page 290
page 304
Those might not show enough details. Maybe someone will post photos. If the Shop Manual has a good photos/illustrations of the entire run of linkages, maybe someone will post direct links?
Thanks but its not showing enough detail. Im needing a pic pf where the linkage goes underneath The cab and tiess onto the rod shaft. Is there a spring that attached to anything??
can't get much more 'detail' than those parts manual illustrations Tim provided that show every part, is there a spring listed attached to anything?
Looks like there a spring but not sure. not to be lazy but if someone could snap a couple pics i should would be very thankful
benfur,
There is a spring and it is not discernible in those illustrations. Maybe someone will post a photo?
Ben, they should have come from the factory with a two piece rod
like this. this is a view from the driver side from the back to
the front. It shows the return spring.
http://www.pbase.com/dennygraham/image/134021809
If you have a single rod then it probably replace the two at
some time in the past 60 years and the single rod would have a
tab spot welded on the rod where the front of the spring would
be hooked.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks thats the pic i needed. I have the spring but missing the extension anyone know where to buy one at?
Here is a reproduction of the assembly. That's more than what you need.
Try posting a Part Wanted ad in the Swap Meet?
I got an extension from Turner junk yard in California.
Roland
46 Chevrolet 3/4 ton in Minnesota
On my '52 3600 the spring is in the pull assembly. This connects to the Emergency brake control rod by way of the center connection. The center connection should be placed in a downward direction to connect to the Emergency brake pull assembly
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
