0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | Can some one post a pic of the emergency brake control rod. I need a pic of the whole linkage took it off to paint the frame now forgot how it goes back together a pic would help thanks guys
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year and size truck?
| | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | | | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | have checked the shop manual brake section? Bill | | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | Yes sir went thru and could not find a pic of how it goes together. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Check illustrations on: page 290 page 304 Those might not show enough details. Maybe someone will post photos. If the Shop Manual has a good photos/illustrations of the entire run of linkages, maybe someone will post direct links? | | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | Thanks but its not showing enough detail. Im needing a pic pf where the linkage goes underneath The cab and tiess onto the rod shaft. Is there a spring that attached to anything?? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | can't get much more 'detail' than those parts manual illustrations Tim provided that show every part, is there a spring listed attached to anything?
Bill | | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | Looks like there a spring but not sure. not to be lazy but if someone could snap a couple pics i should would be very thankful | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | benfur,
There is a spring and it is not discernible in those illustrations. Maybe someone will post a photo?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ben, they should have come from the factory with a two piece rod like this. this is a view from the driver side from the back to the front. It shows the return spring. http://www.pbase.com/dennygraham/image/134021809If you have a single rod then it probably replace the two at some time in the past 60 years and the single rod would have a tab spot welded on the rod where the front of the spring would be hooked. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | Thanks thats the pic i needed. I have the spring but missing the extension anyone know where to buy one at? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is a reproduction of the assembly. That's more than what you need. Try posting a Part Wanted ad in the Swap Meet? | | | | | Joined: Jul 2006 Posts: 4 New Guy | | New Guy Joined: Jul 2006 Posts: 4 | I got an extension from Turner junk yard in California.
Roland 46 Chevrolet 3/4 ton in Minnesota
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | On my '52 3600 the spring is in the pull assembly. This connects to the Emergency brake control rod by way of the center connection. The center connection should be placed in a downward direction to connect to the Emergency brake pull assembly
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
