8 members (cmayna, Gdads51, Joe H, Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, 1 invisible),
107
Mod | | | Forums66 Topics128,169 Posts1,057,037 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 46 | will 1953 3100 rear brake backing plates, drums etc fit my 1950 3100 truck. My goal is to replace the huck style system. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | the fronts will fit, I used them on the front of my 46 1/2 ton, you just have to redrill the bottom holes and use spacers and the front hubs and drums will slide right on you're spindles
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Why are you replacing the Huck brakes??? Properly installed and adjusted they stop the truck fine just like any other brake. They'll lock the brakes up at any speed, I've done it many times. Now if you're planning on running on a road course that's a different story.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | Why are you replacing the Huck brakes??? They'll lock the brakes up at any speed, yeah like denny said and ive done it also but probably not as many times as denny. i have them on al three of my trucks and they will throw the passenger out through the window. oh and all time you'll save you could be out enjoying a ride.  | | | | | Joined: Jul 2013 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 46 | I am missing all of the huck emergency brake hardware both sides....if I could fine what I need I would keep them...any leads for the parts would really help. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I agree with the recent posts. The only reason I can think of is the cost and availability of parts? | | |
