7 members (J Lucas, Gdads51, 55shaker, Lightholder's Dad, wilbur53, Shaffer's1950, Eileen), 106 guests, and 3 robots.
Topics128,079
Posts1,056,297
Members48,441
Since my 49 3100 has stock doors where in order to lock the truck you have to lock the driver's door and crawl out the passenger door and lock it with the key, I decided I wanted power remote door locks. I bought a kit on ebay for $29.00.
The first thing I discovered is that AD doors are very narrow especially up where the door lock mechanism is and also the passenger door can only be locked with the key so there is no sliding bar to engage with the power door lock. I decided instead to put the power door lock actuators behind the door posts and they would push a pin into the back of the doors to lock them. With this set up you also avoid having any electrics in the doors.
Here is the bracket to mount the actuators
http://img.photobucket.com/albums/v518/Blacktailer/1949%20Chevy/IMG_5451_zps720f7397.jpg
And here is the bracket with an actuator installed
http://img.photobucket.com/albums/v518/Blacktailer/1949%20Chevy/IMG_5453_zps5fdb2670.jpg
Note that the first 2 pictures are for the passenger side.
Here is the actuator installed behind the door post on the driver's side
http://img.photobucket.com/albums/v518/Blacktailer/1949%20Chevy/IMG_5447_zps354c8747.jpg
Here is what it looks like from the door side in the open position. The lock pin is the second one from the top.
http://img.photobucket.com/albums/v518/Blacktailer/1949%20Chevy/IMG_5446_zps1c317998.jpg
Here it is in the closed position.
http://img.photobucket.com/albums/v518/Blacktailer/1949%20Chevy/IMG_5448_zps83043859.jpg
And here is what the door looks like.
http://img.photobucket.com/albums/v518/Blacktailer/1949%20Chevy/IMG_5445_zpsd9b73adc.jpg
It took me a day to fab the brackets because of all the head scratching in trying to figure out how to make this work and a day to install everything.
Pretty slick...what do you have for a fail safe?
Don
1950 Chevy Panel Delivery. Purchased in 2008 that was in a family for 35 years. Restomodded in 2006.
There is also a switch to activate the locks. Other than that and the remotes, you have to crawl out the window if you are inside.
If the battery is dead and you are on the outside ie you left the lights on, the battery is in the engine compartment so I can jump it.
Might need to fuse outside the cab...
On a previous post you were looking for running board strips.
Did you find a solution? I posted on that thread a few days ago about possibly repurposing the ss center windshield strip for this.
Don
Hmmm... Might be a good idea to fuse them on the outside, I hadn't thought of that. Yes, the running board strips were just what I was looking for. thumbs_up
Haven't bit the bullet yet and may still end up with 3M tape because of the price.
I may just see how the paint holds up since this won't be a work truck.
