7 members (49nut, moparguy, ndkid275, Barry Martak, tclederman, kades51, 1 invisible),
78
Mod | | | Forums66 Topics128,133 Posts1,056,396 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | I have a 1956 235 and as ususal the rear main leaks. A couple of years ago I saw an article in a magazine about a machine shop milling the rear main area to fit a 1 piece rear main seal. Did anybody else see the article or know anything about it? If so, I would like to try it on mine if anybody can help me locate the info.
Brad | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,814 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,814 | If there's enough of a demand for the single-piece seal modification, I can build an adapter for my Van Norman cylinder boring bar and provide that service. Counting the cost of the seal, and setup and machining time, it would be about a $150.00 procedure, plus shipping to middle Tennessee. I would need the bare block, with the rear main cap installed, to do the job. Jerry
| | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | WOW that was quick. I appreciate the input and when I get it torn down to see if its a shimmed model or not I know where to look now. Dave lots of good info in that article and Hotrod, Tennesee is only a days drive for me.....I'm 12 hours from Nashville | | | | | Joined: Feb 2004 Posts: 29,814 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,814 | I've seen that article before, and it would be a pretty simple setup job to get a piece of 3/4" steel plate surface-ground on both sides so it could bolt to the back of the block with the bellhousing bolt holes and support a cylinder boring bar. The cat's paws on the boring bar will center the cutter in the rear main bearing bore, and the boring cutter can be set to a series of diameters that will end up a few thousandths below the outside diameter of the one-piece seal. It would probably require somewhere from 6 to 8 passes with a square-ground tool to make the seal counterbore. Then the seal can be driven into place after the crankshaft is installed. Jerry
