9 members (FishinToms53, Otto Skorzeny, Gray_Ghost, Wally / Montana, TooMany2count, 1955 1 Series, baldeagle, KEVINSKI, 1 invisible), 90 guests, and 0 robots.
Topics128,052
Posts1,055,741
#673450 08/27/2010 2:49 PM
Can you tell me the difference between the vacuum advance on the 216 from the 235. The reason I'm asking is, I have both of then. The only thing I see is how they sit under the distibutor. I have the steel line off my 216 and the vacuum advance. The vacuum advance off the 235 was pretty shacky so I used the 216 advance. Will it work OK?
THanks again. Chuck 49
As long as it bolts on securely, I don't see a major problem with using it. The degrees of advance might be slightly different, but it would be necessary to research that information using the distributor part number in a GM specification book. Chances are it won't make a noticeable difference.
Stovebolt people never cease to amaze me! Truly amazing! Your the best. thank you so much! Answers and pictures not minutes after I post it. It is nice to know you guys are out there.
Thank you again!
Chuck 49
