| | | Forums66 Topics128,260 Posts1,058,322 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | Can you tell me the difference between the vacuum advance on the 216 from the 235. The reason I'm asking is, I have both of then. The only thing I see is how they sit under the distibutor. I have the steel line off my 216 and the vacuum advance. The vacuum advance off the 235 was pretty shacky so I used the 216 advance. Will it work OK? THanks again. Chuck 49
| | | | | Joined: Feb 2004 Posts: 29,941 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,941 | As long as it bolts on securely, I don't see a major problem with using it. The degrees of advance might be slightly different, but it would be necessary to research that information using the distributor part number in a GM specification book. Chances are it won't make a noticeable difference. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | Stovebolt people never cease to amaze me! Truly amazing! Your the best. thank you so much! Answers and pictures not minutes after I post it. It is nice to know you guys are out there. Thank you again! Chuck 49 | | |
