| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | opening too big? The old thrust plate, that I broke, had a center opening that slides over the end of the cam, that fit nice and snug on the shaft, about 1.25" diameter hole. The new thrust plate has an opening that is oversized, about 1.5" in diameter. Does this matter? Will it create some wobble, or play at the front of the shaft when those timing gears get going? Thanks | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The cam will center itself in the bearings in the block, so the oversize hole in the thrust plate won't result in any wobble. Is there some reason the correct thrust plate isn't available anymore? Some timing gears have a shoulder that fits into the hole in the thrust plate, so you might have to match up the correct gear with the plate. Jerry
| | | | | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | Thanks Jerry, I didnt get any explanation as to the correct plate being available or not. I ordered this one from my local Carquest. And this is what they sent. Matches up fine everywhere else, and there isnt any shoulder on the back of the new gear, so I'll assume I'm good to go with what I got. Thanks again, a little re-assurance is a powerful thing when doing something for the first time. Tony | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | If the gear doesn't have a shoulder that establishes the correct end play, you'll need to press the gear onto the cam with a feeler gauge or something similar between the gear and the plate to keep it from getting too tight. It sounds like that plate is supposed to work with a shoulder on the timing gear a few thousandths thicker than the thrust plate, to establish the proper front-to-back clearance. Jerry
