| | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Does anyone know where to get all the different sized clutch head bolts from? I am trying to find the small ones that run along the vent inlet just below the windshield and behind the hood. There are 5 small clutch heads there. Thank you. 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Clutch-head bolts from Totally Stainless and/or McMaster-Carr? All of these vendors have carried one or more sizes/styles of clutch-head bolts/screws (over the past 10 years). http://www.restorationspecialties.com/ (they had several styles/sizes) Jim Carter Classic Parts of America LMC or Brothers | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | And those are about the only places you'll find them.
~Jim
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hey all, Just called Totally Stainless and McMaster-Carr. Both told me they do not carry the Clutch Head bolts.
Jon
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Mr G's carries some. http://www.mrgusa.com/Bob | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Hey all, Just called Totally Stainless and McMaster-Carr. Both told me they do not carry the Clutch Head bolts.
Jon Yes,as I recently found out myself. Sorry I misled you. You might consider button head screws which look slightly similar, unless of course you are trying for a correct restoration.
Drew
~Jim
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Yes, I am trying to restore the truck with original clutch heads. I am trying to educate myself on where they all went. Were they used on the steering column rubber flange and tranny cover? I placed an order with Filling Station for the following sizes: CLUTCH-HEAD 8-32X1/2 MACHINE SCREW 1/4-20 X 3/4 10 X 1/2" CLUTCH HEAD METAL SCREW-ZINC 5/16-24 X 1 1/4 CLUTCH HEAD FLAT. I really would like to know what size I need for the fresh air vent cowl that mounts on the cab just below the windshield and behind the hood. I looked in the Chevy shop and assembly manuals and they really dont tell much of where all the bolts are located through out the truck. Am I missing something? Thank you all for the help and patience with me!
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | on a 57 clutch heads were used on the 2 screws in the door that hold the bottom of the division bar [round head], the trans floor cover [flathead countersunk] and the stepside fenders [round head] ... all others are phillips, including the cowl vent cover, inner air vents and seal at rear of hood on cowl, shifter on column, dash trim strip inside windshield, glovebox - steering column clamp is bolts
the asembly manual should show exactly where, how many, and size of every nut and bolt, may not indicate if clutch or phillips
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Thank you Bill, I will take a closer look today....
Jon
