3 members (klhansen, Nick in Manitou, TooMany2count), 322 guests, and 4 robots.
Topics128,089
Posts1,056,140
Members48,436
#356472 01/05/2008 12:18 AM
Just wondering if anyone has any experience with 8 volt batteries.
I have used them in 6 Volt systems on tractors and at one time, had one in a 51 ford
The only negetive I can recall is that I would occsionally
burn out a bulb. The 6 volt generator wouls charge the 8 volt fine simply by adjusting the voltage regulator.
It seems to be a solution to the slow cranking problem.
Any comments?
Wally Body #356488 01/05/2008 12:49 AM
If all your cables are the proper size and your grounds are clean,starter and charging system is in good shape,there shouldnt be a slow cranking problem.
Lotsa times a cable will get changed with a smaller gauge,,then the problems start.
Any comments? Marty is correct.
. . . a simple solution to slow cranking problems.
1. 2/00 battery cables - both cables (unless care has been taken, most cables used over the past 40 years are for 12v systems and inadequate for a 6v system).
2. Good, clean connections at all ends of battery cables and at all ends of all ground cables.
3. Rebuild the starter (or get it rebuilt or buy a new starter).
and/or
4. Get a good 6v battery (such as an Optima Red Top).
If all the above do not result in adequate cranking, maybe your engine is too tight.
Tim
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
What Marty said....Joe
#356719 01/05/2008 3:48 PM
Ex Hall Monitor
Ex Hall Monitor
Ditto the above. An 8v battery is a bandaid for a different problem.
Tiny #357297 01/06/2008 8:50 PM
Here is a word from someone who is using an 8-volt battery. I bought it before I started reading the posts from the wiser guys on the Stovebolt page. On the one hand, after having followed these kinds of posts for a coupla years, I will go back to a 6-volt battery when my current one dies. The last few posts and many others like them make a lot of sense to me. On the other hand, I have had none of the problems (yet) that the wise guys have predicted. Contrary to the advice of the Parts Store, I had to adjust the voltage regulator (of course), but since then I have had no problems.
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
Still using a 8v in the 49 just because that is what i had at the time. this sping will put the 6v back into it, had to small of a cable on the pos. side, should be fine now
Drive with Pride. mike j
family pic
dakota #357572 01/07/2008 1:18 PM
Thanks guys for the replies.
I realize that an 8 volt would only be a temporary solution to the problem of slow cranking,the starter likely needs a rebuild. 56 years isn't bad for starter life!!
All the cables are new,(and correct) so I guess we'll go with a rebuild kit.
Ex Hall Monitor
Ex Hall Monitor
One additional thing I did that helped mine a lot is connecting the ground cable directly to the starter. That makes the current path direct instead of traveling through a bunch of rusty bolt connections.
