BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
8 members (Leo, greenie-reddy, Deegs53, Cosmo, Otto Skorzeny, TooMany2count, DennisM, 1 invisible),
538
robot. | Key: Admin,
Mod | | Forums66 Topics126,781 Posts1,039,297 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Dec 2004 Posts: 52 'Bolter | 'Bolter Joined: Dec 2004 Posts: 52 | I have a '54 chevy 4 speed trans I got for almost nothing, but the gear shift lever is missing. There is a junk truck on a friends farm that is rotted away gone, total trash almost but the trans is in it, but it's up on a hill, can't get to it etc. I just want to get the gear shift lever. how does it come out?
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | Joined: Mar 2002 Posts: 9,112 'Bolter | 'Bolter Joined: Mar 2002 Posts: 9,112 | You push down on the tower cap and rotate it slightly counter clockwise. It will then release. The shop manual shows a tool. I use a mokey wrench on its side. | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | Shop Shark Joined: Jan 2010 Posts: 4,263 | Push down on retainer and turn ...pic... ...click... I think it's ccw Junkyard.... might need some penetrating oil to loosen up the retainer | | | | Joined: Dec 2004 Posts: 52 'Bolter | 'Bolter Joined: Dec 2004 Posts: 52 | counterclockwise then lift it up I guess? Thanks!!!Can I use a crescent wrench on it'side?
| | | | Joined: Dec 2004 Posts: 52 'Bolter | 'Bolter Joined: Dec 2004 Posts: 52 | HOLY COW! that video clip is perfect. Thanks guys!! this site is awesome! I am trying to make my own side by side out of my extra 248 I6, my 4 speed, and one of my extra rears, and my extra steering column......... It will be one tough mule (if I actually get it made.
| | | | Joined: Jul 2013 Posts: 388 'Bolter | 'Bolter Joined: Jul 2013 Posts: 388 | when I took mine apart for inspection, I used a roll of electrical tape, slid it down the shaft, pushed and turned ccw. worked like a charm cause the cardboard middle of the tape roll kinda 'gripped' onto the retainer. | | |
