1 members (delky),
127
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | Good Evening All! Does anyone know where to buy lamp sockets for the speedometer bulbs. Preferably wired so I can splice them on to my wiring harness.
"53 Chevy 3100 Many thanks! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | all the vendors have plastic sockets, and probably could find the same at NAPA or such, they'll all have pigtails - http://www.riwire.com/ seems to be the only place with original style metal ones Bill | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | You are looking for a BA9 socket. You should be able to find them at about all of the vendors. I haven't looked for them at the local FLAPS but they may stock them as well. YNZ sells them but they have a $20 minimum order.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Summit has a pretty good selection of light sockets, 427 listed. Orta be able to find something there, I haven't looked thru them all. DG
Denny G Sandwich, IL
| | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | Thanks to all you guys ... I'll be checking it out this week! | | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | OK ... This socket has annoyed me for a while .... because none of the vendors carry them ..plastic or otherwise.. At Tiny's suggestion I went to YNZ and they have the solution ... metal ones just like the originals, one piece so they don't break apart when you try to remove them for a bulb change ... like the ones that were attached to my repop wiring harness. I had them make it up using @25 socket with a 6 inch pigtail in my wire color of choice ... fits like a glove and Chris @YNZ is nice as could be. Super service. Thanks for the help and I hope this helps someone else!
