6 members (TUTS 59, HandyAndy, dt235sd, Bill Hanlon, 2-Ton, Brian Moore), 109 guests, and 2 robots.
Topics128,060
Posts1,055,836
Members48,427
Good Evening All!
Does anyone know where to buy lamp sockets for the speedometer bulbs. Preferably wired so I can splice them on to my wiring harness.
"53 Chevy 3100
Many thanks!
all the vendors have plastic sockets, and probably could find the same at NAPA or such, they'll all have pigtails - http://www.riwire.com/ seems to be the only place with original style metal ones
I got a nice set of originals from a Post in the parts wanted section.
Already wired and ready to splice.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=postlist&Board=17&page=1
Ex Hall Monitor
Ex Hall Monitor
You are looking for a BA9 socket. You should be able to find them at about all of the vendors. I haven't looked for them at the local FLAPS but they may stock them as well. YNZ sells them but they have a $20 minimum order.
Summit has a pretty good selection of light sockets, 427 listed.
Orta be able to find something there, I haven't looked thru them all.
DG
Denny G
Sandwich, IL
Thanks to all you guys ... I'll be checking it out this week!
OK ... This socket has annoyed me for a while .... because none of the vendors carry them ..plastic or otherwise.. At Tiny's suggestion I went to YNZ and they have the solution ... metal ones just like the originals, one piece so they don't break apart when you try to remove them for a bulb change ... like the ones that were attached to my repop wiring harness. I had them make it up using @25 socket with a 6 inch pigtail in my wire color of choice ... fits like a glove and Chris @YNZ is nice as could be. Super service.
Thanks for the help and I hope this helps someone else!
