2 members (RLB, Guitplayer),
139
2
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 16 New Guy | | New Guy Joined: Jun 2008 Posts: 16 | this is a GMC may be out of 1 ton truck.some numbers i found. ferro 2 L 262 ser # begins with B i'm looking for a valve cover gasket Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy herme, could you please tell us the year at least, and the whole serial number, and some casting numbers [raised], six or seven digits would help. | | | | | Joined: Jun 2008 Posts: 16 New Guy | | New Guy Joined: Jun 2008 Posts: 16 | thank you I will get back to you with numbers | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The first 3 numbers after the B is the engine size. | | | | | Joined: Jun 2008 Posts: 16 New Guy | | New Guy Joined: Jun 2008 Posts: 16 | Hi guys here are more numbers. B 228460269. also 2194819 engine came out of 1953 GMC truck | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy herme, as cletis has said the first three digits after the "B" in the engines serial number give you the engines cubic inch displacement [c.i.d.], this is a quirk of GMC engines. The casting numbers can come in handy if you are trying to figure out if the engine is completely stock, or if some parts have been replaced, hope that helps. | | | | | Joined: Jun 2008 Posts: 16 New Guy | | New Guy Joined: Jun 2008 Posts: 16 | my thanks to shark and cletis
herme | | |
