0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#427579 06/28/2008 9:09 PM
this is a GMC may be out of 1 ton truck.some numbers i
found. ferro 2 L 262 ser # begins with B
i'm looking for a valve cover gasket
herme #427609 06/28/2008 10:35 PM
3B Offline
Hy herme, could you please tell us the year at least, and the whole serial number, and some casting numbers [raised], six or seven digits would help.
3B #427666 06/29/2008 1:28 AM
thank you I will get back to you with numbers
The first 3 numbers after the B is the engine size.
Hi guys here are more numbers. B 228460269.
also 2194819 engine came out of 1953 GMC truck
3B Offline
Hy herme, as cletis has said the first three digits after the "B" in the engines serial number give you the engines cubic inch displacement [c.i.d.], this is a quirk of GMC engines. The casting numbers can come in handy if you are trying to figure out if the engine is completely stock, or if some parts have been replaced, hope that helps.
3B #427795 06/29/2008 4:34 PM
my thanks to shark and cletis
herme
