6 members (66flea, moparguy, ronsway, TUTS 59, 1955 1 Series, 1 invisible), 347 guests, and 4 robots.
Topics128,154
Posts1,057,015
#1613070 10/11/2026 7:51 PM
Now that I have a working wiper motor I would like to add a dual diaphram pump but were they a option on trucks or something only a car would have. Now that I have the wipers working the suppliers are out of stock and I think there is one on a car in the local old junkyard and are kits available,
I believe they were mostly used on big bolts with vacuum operated 2-speed axles. But, yes, they can be used on pickups or cars. I found one on a 235 that was going to go in a 1937 pickup. There happened to be a spare in the seat of the "project" truck. Should have snagged that one as well.
Kits are available from Then and Now Automotive. They'll also rebuild yours if you send it to them for about $50 plus the cost of the kit. Pretty reasonable, if you ask me. They do a fabulous job. I have many thousands of miles on the pump they rebuilt for me 4 or5 years ago.
Call them, their website is useless for ordering.
447 Washington St
Weymouth, Ma 02188
Ph: 781.335.8860
Fax: 781.335.1925
https://www.thenandnowautomotive.com/auto-parts-store
7
7 Offline
My '57 Big Bolt has HydroVac brakes and I added a 2 speed differential, the vacuum from the engine alone is sufficient to operate both of those components. My truck came standard with electric wipers so I can't comment on that function. I added a vacuum reserve tank when I incorporated the 2 speed but I think it would have worked ok regardless. The one difference with my truck vs. an earlier model is that it has the 283 V8 and may produce vacuum better than the inline 6.
1957 Chevrolet 5700 LCF 283 SM420 2 speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto, 1978 Yamaha DT175, 1999 Harley Davidson Softail Fat Boy
On a big rig there's usually enough room to add a vacuum reservoir tank- - - - -the bigger the better. That usually eliminates the need for a vacuum booster fuel pump. I like repurposing medium-sized refrigerant gas tanks mounted under the bed or inside frame rails, with one way check valves to store enough vacuum for a few brake applications if the engine stalls.
Just so I can play along is this what we are talking about? NOS 292.
Old enough to know better, too young to resist.
Yes- - - -the upper chamber pumps fuel- - - -the lower one assists the manifold vacuum, especially when the throttle is opened and normal vacuum drops too low to operate windshield wipers, brake boosters, or other vacuum powered accessories.
If your looking for a pump to rebuild try
Old Car Parts in Portland OR. Model 9803 or 9797 would be nice. I am rebuilding 2 right now got the parts from Then And Now.
Shade Baby
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
Thanks HL. Since I'm running a 6-71 on my 292 I have a MPP scroll vacuum pump. I have electric wipers so I just need it for brakes. They say it doesn't need a reservoir but I think I will run a small one anyway. It's supposed to be quiet.
Off to the junkyard to find the car that has one,I remember seeing one when I started thinking about getting the wipers working. I was hoping there was a vendor at Hershey that delt with fuel pumps but did not see one but there was one that had wiper motors.
