Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (pauld, DennisM, Chev4t6, lumbersawyer, Phak1, J Lucas), 110 guests, and 0 robots.
Topics128,279
Posts1,058,593
Members48,492
#1613070 10/11/2026 7:51 PM
Now that I have a working wiper motor I would like to add a dual diaphram pump but were they a option on trucks or something only a car would have. Now that I have the wipers working the suppliers are out of stock and I think there is one on a car in the local old junkyard and are kits available,
I believe they were mostly used on big bolts with vacuum operated 2-speed axles. But, yes, they can be used on pickups or cars. I found one on a 235 that was going to go in a 1937 pickup. There happened to be a spare in the seat of the "project" truck. Should have snagged that one as well.
O Online: Content
Kits are available from Then and Now Automotive. They'll also rebuild yours if you send it to them for about $50 plus the cost of the kit. Pretty reasonable, if you ask me. They do a fabulous job. I have many thousands of miles on the pump they rebuilt for me 4 or5 years ago.
Call them, their website is useless for ordering.
447 Washington St
Weymouth, Ma 02188
Ph: 781.335.8860
Fax: 781.335.1925
https://www.thenandnowautomotive.com/auto-parts-store
1950 Chevrolet 3100 (Ol' Roy)
7
7 Offline
My '57 Big Bolt has HydroVac brakes and I added a 2 speed differential, the vacuum from the engine alone is sufficient to operate both of those components. My truck came standard with electric wipers so I can't comment on that function. I added a vacuum reserve tank when I incorporated the 2 speed but I think it would have worked ok regardless. The one difference with my truck vs. an earlier model is that it has the 283 V8 and may produce vacuum better than the inline 6.
On a big rig there's usually enough room to add a vacuum reservoir tank- - - - -the bigger the better. That usually eliminates the need for a vacuum booster fuel pump. I like repurposing medium-sized refrigerant gas tanks mounted under the bed or inside frame rails, with one way check valves to store enough vacuum for a few brake applications if the engine stalls.
Just so I can play along is this what we are talking about? NOS 292.
Yes- - - -the upper chamber pumps fuel- - - -the lower one assists the manifold vacuum, especially when the throttle is opened and normal vacuum drops too low to operate windshield wipers, brake boosters, or other vacuum powered accessories.
If your looking for a pump to rebuild try
Old Car Parts in Portland OR. Model 9803 or 9797 would be nice. I am rebuilding 2 right now got the parts from Then And Now.
Shade Baby
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
Thanks HL. Since I'm running a 6-71 on my 292 I have a MPP scroll vacuum pump. I have electric wipers so I just need it for brakes. They say it doesn't need a reservoir but I think I will run a small one anyway. It's supposed to be quiet.
Off to the junkyard to find the car that has one,I remember seeing one when I started thinking about getting the wipers working. I was hoping there was a vendor at Hershey that delt with fuel pumps but did not see one but there was one that had wiper motors.
Came up empty handed but found a aftermarket a/c bracket for a 235 that I will probably never use but got it since its the first one i ever seen.
Jeff - Post an ad in the Truck Parts Wanted forum. You'll likely find another 'Bolter that will have a combination fuel/vacuum pump they will part with, or at least help on finding sources.
Great find on the aftermarket a/c bracket! thumbs_up
~ Dan
1951 Chevy 3 window 3100
I have one coming but its a older rebuild so I will be sending it out.
I
I Offline
I just installed one on my 1962 Grumman Olson Kurbside step van which was built on a Chevy P30 platform with a 235 in it. It was a direct swap for the single stage pump. Although, I did have to click the fuel side so that the fuel lines would match the position of the In and Out of the fuel pump.
I have a splitter for the vacuum lines in the engine bay. One port on the splitter is labelled MAN. That takes a vacuum line from the manifold. Another port on the splitter is labelled V.P. That has a vacuum line going from it to the OUT barb on the vacuum pump. Finally, there is a hose going from the IN side of the vacuum pump to a tee which connects to the port on the splitter that goes to my two wiper motors. There is a fourth port on the splitter I have capped off that would be used if I had a windshield washer bottle.
The splitter has one way check valves built into it that no longer work, so I used external one way check valves instead. My wipers now work well at idle, and under load.
I've attached some pics, hoping they might help you out.
~~ Konstantine
1962 Grumman Olson Kurbside/Chevy P30
Follow in the DITY
The older rebuilt pump arrived and will be checking out getting it rebuilt for today's fuel.
Depending on the model, you may need to disassemble it before ordering a rebuild kit from Then and Now. The pushrod for the vacuum portion uses a couple different configurations. That's what I needed to do on mine. Tom at Then and Now let me know about that and got me the correct kit.
