4 members (Joe H, 68ironhead, baldeagle, 78buckshot), 72 guests, and 5 robots.
Topics128,014
Posts1,055,329
Members48,419
Is there a pull back spring for the brake pedal on 41’ half ton, model AK? If so, how is it attached?
Any help will be appreciated.
Ken
U
U Offline
My '46 is setup like this. The brake and clutch use the same return springs. Brake spring connects using a "Z" bracket attached to the side engine pan.
~ John in Utah
1946 1/2Ton w/4-speed manual transmission w/1960 235 engine
Here We Go
Follow in his DITY Bay
- If you think about it, it has been one year ago today!
CuzzFuzz - John's '46 setup is the same as your '41. Check out my reply post in John's DITY that contains the part number info for those springs.
Both are the same GM# 368244 and a few can be found on ebay currently, as well as repops from Chev's of the 40's and The Filling Station.
How does the brake spring/link attach to the pedal?
Take a look at this picture that came from the VCCA thread I posted the link to in John "UtahYork"s DITY thread above.
I've resized the picture and reattached it here so you can hopefully see it better.
Here’s another photo showing the springs and brackets used on the Sparky, ‘46 Chevy 1/2 ton.
