5 members (Rudedog53, Randy Baumann, Spikeytop, 50Chevy3100, Otto Skorzeny), 86 guests, and 6 robots.
Topics128,181
Posts1,057,191
Members48,465
Is there a pull back spring for the brake pedal on 41’ half ton, model AK? If so, how is it attached?
Any help will be appreciated.
Ken
U
U Offline
My '46 is setup like this. The brake and clutch use the same return springs. Brake spring connects using a "Z" bracket attached to the side engine pan.
~ John in Utah
Here We Go
Follow in his DITY Bay
CuzzFuzz - John's '46 setup is the same as your '41. Check out my reply post in John's DITY that contains the part number info for those springs.
Both are the same GM# 368244 and a few can be found on ebay currently, as well as repops from Chev's of the 40's and The Filling Station.
~ Dan
1951 Chevy 3 window 3100
How does the brake spring/link attach to the pedal?
Take a look at this picture that came from the VCCA thread I posted the link to in John "UtahYork"s DITY thread above.
I've resized the picture and reattached it here so you can hopefully see it better.
~ Dan
Here’s another photo showing the springs and brackets used on the Sparky, ‘46 Chevy 1/2 ton.
