| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 51 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 51 | I found an inline 6 Chev engine that I was told is a "rebuilt" 235 from 1962 and hasn't been run for 10 yrs. I got it started with fresh gas from a jug and let it idle for about a minute until it stopped smoking, it sounds ok.
The casting numbers under the distributor are 3769716, the numbers stamped into the flat surface to the left of the distributor are F0112A.
I can't find the block number in my Chev & GMC engine number book. Can someone tell me what this engine is?
Thanks | | | | | Joined: Sep 2009 Posts: 5,777 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,777 | Casting number "3769716" is listed in my resource documents as a 1958-62 Chevy 235 Truck engine.
The serial number "F0112A" is difficult to decode without knowing the blocks date casting code info. Look for raised (not stamped) single letter followed by a small space, one or two digits, followed by another small space and a single digit located to the rear of the stamped serial number pad.
If you can provide that info, we can better define what year engine you have and possible confirm the serial# as well.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2006 Posts: 51 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 51 | Ok, I was able to find some raised numbers and letters mostly obscured by the starter motor. They are CON4 A 5 1
Thank you for the help. | | | | | Joined: Sep 2009 Posts: 5,777 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,777 | Not sure if you've decoded those but here it is if you didn't:
CON4 = Conveyor number 4 of the assembly line
A = January - 5 = 5th day of January - 1 = 1961 model year
