Please understand this is not a rebuilding kit. If you need one of those, please contact Jon (CarbKing). That is the only place where you'll find the proper kit.
This is for the four CNC laser cut gaskets (shown below) you will need if you have reason to open your carburetor and service or adjust anything. This set is for the automatic choke models used on the 235 (like the YF2101S, YF3211S and any similar models). Please let me know if you need me to make these for the Carter YF models used on the 216 engines.
Carter suggests you replace the gaskets anytime you have to open the carburetor. That might happen for a number of reasons: need to replace the diaphragm, need to replace or adjust the float, need to clean it inside, need to clean the auto-choke mechanism, something caught in the needle/seat and need to remove it, need to change the metering rod due to moving to a higher/lower altitude...lots of possibilities. These are all made from Fel-Pro material.
$14 delivered to any US address or $15USD delivered to any other country.
If you want to buy a set (or if you want two or more sets so you'll always have gaskets handy) just send a PM, tell me what you need and your postal address. Because of PayPal's fees I'm not using them any longer but am happy to take mail-in payments.
Please tell me if you have any questions.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
