1 members (55shaker),
42
Mod | | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99966 03/19/2007 2:16 PM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I have a perplexing problem with my '42 PU...it has a 235 w/ 12V generator & starter...plus a GM Mini HEI and an 12V coil. The truck ran fine for couple of months...during the last NE coldspell it sat for a week (inside garage) after that week I started it up and it ran for a few seconds and stalled. I've was unable to restart it. We troubleshot the problem and the truck was getting power through the coil. We thought we had a major flooding problem...but after careful remediation we found that was not the case. We moved on to other potential causes...lo and behold we found that the HEI module in the distributor had failed.(It like nearly everything on the truck was new)...What could have caused this failure? and how do I prevent it from happening again? | | |
#99967 03/19/2007 2:21 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | steveg,
Is the HEI unit actually a GM unit and does it call for a specific coil just for that unit. The modules can and do fail..have you crossed paths with a black cat recently?
Stuart | | |
#99968 03/19/2007 9:03 PM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Stuart...good question on the coil...the GM HEI (from Tom Langdon) did initially come with a modern modular style coil but we replaced it with a similarly rated cannister style coil (also from Langdon). Could a power surge burn the module? Coincidentally, the radio also went out at the same time (its wired through the ignition). | | |
#99969 03/19/2007 9:22 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | steveg,
My first thought was improper coil, but as you note, the round coil you bought from Langdon has his blessing for this setup. Technically, the coil is on the secondary side of the ignition, so it probably wouldn't affect the module anyway.
I don't know if a voltage spike would take out the radio or the solid state module, plus I don't know if a generator is capable of producing such a thing. My first thought was that maybe the key was left on and something didn't like that.
From what I understand, these modules can and do fail. Maybe analyzing the type of failure to the radio would shed some light on the problem.
It could be coincidental. If the radio was fused, would the fuse pop on a voltage spike? I'm asking more questions then I am answering.
Stuart | | |
#99970 03/19/2007 10:27 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You better check your charging voltage. Sounds like it might be too high & burning out solid state components. The wrong coil could cause a module failure. The original HEI dist requires a silicone grease under the module when it is installed. It transfers heat away from it. I don,t know about the aftermarket dist. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#99971 03/19/2007 10:40 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Is the engine grounded well to the frame & body? I have seen module burnout on non-grounded engines. Brian | | |
#99972 03/20/2007 3:54 AM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | ...the engine is well grounded to the frame, the radio did burn a fuse when whatever happened, happened. We replaced the fuse and it popped again. The radio is a '42-46 accessory radio converted to solid state AM FM...I shipped it back to S&M Electro Tech in MN and they said it is running fine for them...they thought that maybe the battery cables were switched...they were'nt...or maybe the hot wire from the battery crossed/or shorted the ground in or around the ignition. We've now replaced the module and rewired the ignition including a new ignition switch. Truck starts and runs fine again. I'm waiting to get the radio back from MN to see if that works out. But I would really like to understand the potential causes for this kind of malfunction. Thanks for all the help. | | |
#99973 03/20/2007 4:29 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Sounds like most bases have been covered, give it a whirl & let us know how it goes. Brian | | |
#99974 03/20/2007 8:43 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | coil, internal or ex.......ballast, not familiar with 12 volt gen...........must go to alt during the conversion.........
I ran a 12 volt electronic mallory dist on mine, almost drove me nuts trying to find a small gremlin, like it would always start, idle good but got into a habit of dieing at hiway speeds and lower...always would restart.........the problem got really bad so I had to find out..........the module was bad, heating up breaking down..but yet the tests said it was ok.... I bought me a spare for future, it had been on the truck for about 8 yrs so those things happen... the book said to make sure the wires/clip from the dist to the engine were disconnected when ever it was jumped off... I never thought about doing so when I did need to boost.. that may have helped with doing something to the module......... anyway, glad you got it running. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#99975 03/21/2007 2:44 AM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I had a module in my HEI (from Tom Langdon as well) fail - never did figure out why. | | |
#99976 03/23/2007 7:10 PM | Joined: Sep 2006 Posts: 23 Apprentice | | Apprentice Joined: Sep 2006 Posts: 23 | steveg, The previous posters were correct in that the modules go out occassionally and can test good even if they are bad. Another thought that I did not see covered was if you had replaced the wire from the ignition switch to the HEI so that it was not being run thru the original resistor since this reduces the voltage and can overheat the modules too. Just a thought. Happy motoring!
CCB
