7 members (55shaker, Bill Hanlon, Jon G, 78buckshot, TrknGMC, Joe H, 1 invisible),
99
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | I have a 1950 3100 with the stock original suspension and 16" rims. I have read allot about the 3" and 4" drop. I would like to do the 4" drop but concerned that if anything would go bad the 4" and the scrub line would be to low. I really would like to do chrome smoothie 15" rims and fatten the rim up a bit, but not against 16" to keep it somewhat off the ground if i had a flat. What rims and tires are you running with both the 3" and 4" drops from sids? I am not looking to change my springs at this point. Please chime in with info and pictures would be awesome. Thanks Steve | | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | I looked into this some with the stock 16" wheels and didnt expect any issues with clearance from what I saw online and I believe they had advise listed on the SID website too. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Do you want 4" total drop? If you change your tires and wheels, think about whether you want shorter tires too, this will help dictate how much drop you want on your axle. | | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | I used a 3" drop axle from Sid, removed 2 leafs and am running 15x7 rims with 215/70 tires. Gave me about a 6" realized drop. I talked to Sid and he cautioned me about scrub line issues on the 4" axle. I was also able to modify my steering fairly easily with the 3", which is something to consider. | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | @ coffeeman and 46gmcpu, I Spoke with Sid, i am going with the 4" drop axle, my springs appear to be a bit tired so everything should fall into place, I would like to get around 5" so we will see how it looks. I will sort out the wheels once its lowered. I am having him modify all my steering parts so it should be a fairly simple project to reinstall. Still interested to here from some other bolters with the 4" drop and what rim / tires they chose. Thanks again. Steve
| | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | I used Sids 3" drop with Posies springs and a 15x7 rim with 4" backspacing and a 235-75 radial tire. When static the tires will clear the tie rod ends but WILL rub significantly when turning. The steering arms can be modified to rectify the problem but that creates bad Ackerman that you won't be happy with. I recommend going with a 6" wide rim with 3" backspacing and a 215 or 205 tire. Other than that you won't have any trouble.
Dave | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | | | | | | Joined: Jan 2012 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 162 | I got 9/16" spacing from my disc brake conversion. The tires don't rub but it's close. I had to flip my tie rods and am using modern style ends. The trick is getting the caster sorted out. Because of my rake, I don't have near enough caster. I think I need about 6 degrees total. Also check the pitman arm angle for bump steer. Needs to be parallel. | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | thanks, Sid is modifying all the components for my drop and recommends 4 degrees caster for radials. I will be disassembling this weekend, should have everything back for assembly mid feb. then its rim and tire decision time. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | My suspension is all stock but because I'm running radials, I switched to 4° shims and noticed a real improvment in handling. That simple change allowed me to cruise roads at 55 mph that I used to white knuckle at 40mph or avoid all together. | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Be careful when you drop that axle- - - -it's heavy, and even if you only drop it 3 inches, it could mash a toe. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | Be careful when you drop that axle- - - -it's heavy, and even if you only drop it 3 inches, it could mash a toe. Jerry I was gonna suggest he just let the air out of the tires.
| | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | You guys area a hoot, toes are just fine, truck bit my bald head though! one of those rare occasions i wish i had hair to protect it a bit!
| | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Thanks two tone, have them on my parts list!
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | You guys area a hoot, toes are just fine, truck bit my bald head though! one of those rare occasions i wish i had hair to protect it a bit! Ah yes, the bald head. Like my Grandpa (and now myself) used to say, " Less hair to comb, but more face to warsh."
