0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#993998 12/21/2013 4:57 PM
I am refreshing a 50 Suburban frame to replace the damaged one from my 51 pickup. I am wondering if I should remove the bracket on the frame and drill holes for the shackle type rear cab mount or modify the bracket as need be and use a mounting pad. Anyone gone down this road? Thanks for suggestions. John
Hi John,what year are you talking about?
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Oops! Should have added 50 frame, 51Cab
John,
Here are some pictures I made of the 4" x 4" x 1/8" tube steel frame I built to support the cab of my '58 Apache 3100. I drilled holes in the corner of each of the top pieces of TS so I could attach the cab just like it attaches to the chassis. The 4 locking casters make it easy to move the cab around in and in and out of my limited space one-car garage.
http://s1262.photobucket.com/user/Raleigh58/library/Cab%20support%20frame
