4 members (Hotrod Lincoln, Canadian Dump, Dennys28, Phak1), 130 guests, and 4 robots.
Topics128,165
Posts1,056,987
Members48,458
#998570 01/11/2014 7:46 PM
The vendor talked me into this rather than the original cork gasket. The problem with it is that I can't find anything that will stick to it to hold it in place. Has anyone found something that works? Thanks, Scott
I just applied some RTV/Silicone sealant under it and closed the vent. Worked fine. What I don't like is that it compresses and does not rebound. Mine is not out in the weather yet so I can't comment on the seal. I first bought a rubber one and could never figure out how it fits?
The rubber is the one I have but it must have a high silicone content and nothing that I have tried will stick to it. It will fit if glued down but what glue?? I have tried RTV,and a couple of other sealers and they just wipe right off of it. I may have to just get the original cork. Scott
You could try wiping it down with a solvent first. It might have mold release on it. The one I installed was a sponge rubber. The first one was a much thinner molded one that I never could figure out.
Scott,
Someone posted a similar frustration with the black "rubber" step-pads/fender-pads used on COEs (sold only by Jim Carter). The conclusion, after much conjecture about a variety of modern adhesives, was that there was not a commonly available satisfactory adhesive for some silicone rubber parts.
Supposedly, Jim Carter confirmed this unsolved adhesive problem with the COE rubber pads.
That conclusion seems odd. Let's hope someone has personal-experience information/solution (based on experience with these seals made with these recently available silicone rubber formulations).
I had the moulded rubber one from Jim Carter. I used regular multi-purpose silicone, and once it was on I pulled the cowl vent down tight and left it there for a couple days. As was said, wipe it down with thinner or some other solvent first, and there's no reason it shouldn't stick.
Mine seals great in the rain, no problems. Maybe sure the small "lip" goes up.
My 46 GMC on Photobucket
3M makes a rubber molding adhesive (available at most fine auto suppliers). Works great, make sure to wear gloves cause if you get it on your hands, it'll be there for a few days.......
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Scott,
If you find an adhesive that works (or, does not work), please post your findings here.
Good luck,
