| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99912 03/16/2007 4:23 PM | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | Thanks for your help with my head lights now it my tail lights. My brakes and turn signals work however my running lights do not. If I connect a constant hot wire to my hot wire will that do the trick???
Roger
Roger http://www.flickr.com/photos/45469713@N00/?saved=1
#99913 03/17/2007 12:16 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you want to run your battery down. It should feed off of your light switch so it's switchable. Sounds like you have a broken wire or bad switch. I had a similar problem on my old 55.1 panel. I didn't have the money for a new HL switch so I put a toggle switch on the dash to turn my taillight on & off.
#99914 03/18/2007 4:36 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by Tiny: I didn't have the money for a new HL switch so I put a toggle switch on the dash to turn my taillight on & off. I've done that before too. | | |
#99915 03/18/2007 11:44 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Why not troubleshoot the system rather than throwing random fixes at it hoping to cure the problem by magic? Is there power at the tail light terminal of the switch? Is there continuity between the terminal of the wire at the switch and the terminal at the lights? Are the lights properly grounded? Like Tiny said, Sounds like you have a broken wire or bad switch. Find the problem and fix it. Patching in a new wire over an old problem causes nothing but more trouble. | | |
