6 members (TexasA&M48Truck, Charles in CA, MickeyP, Nick in Manitou, Ponchogl, 55shaker), 125 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
So, I am adding a/c to my '52. I want to use the unused control brackets/mounts on the bottom edge of dash for the vent and heater water valve control. My question is what are the original purpose of the various controls and location? I know the heater used a bracket for thermostats on right side of lowest portion of dash (on angle). I see a lot of photos of something to left of steering wheel ( not counting brake release). What was that used for. Many places to add brackets, I just want to know what, where and why.
The controls to the left of the column are for the heater blower control switch, fog lamp switch and the cable pull for Air Flow type heater defroster or door control.
http://www.flickr.com/photos/advance-design_parts_co/8130452603/in/set-72157631870734114
In 1952, the deluxe heater used holes under the dash for:
- to the left of the steering column, a control-cable for the defrost flapper in the heater box.
- just to the left of the heater box, a control rod for the heater heat-control valve
- also, to the left of the steering column, for the heater fan-speed control switch (used with both heaters)
The locations are described, and not so clearly shown, here.
Thanks all. I knew about the heater temp control bracket, I was unsure about the defroster control. My truck did not have the deluxe heater. But, I had acquired the deluxe heater and proper brackets. Again, my plan is to use both for the a/c package to control heater water valve and defrost. Obviously I will use the stock defrost control location and either use the stock temp location or move it to between the ignition switch and steering column. Many factory holes under the dash to mount these brackets.
Moderated by  ndkid275, Phak1
