4 members (Chip O, Hotrod Lincoln, TooMany2count, 1 invisible), 88 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#998933 01/13/2014 4:40 AM
Hi, I'm currently rebuilding my starter for my 1953 and I noticed that the arm that engaged the clutch into the fly wheel has several flat spots on it.
I'd like to replace it but I cannot find it at my usual places (Chevs of the 40's, LMC, Ecklers, Jim Carter).
Does anyone know where I can buy a new shift lever arm for my starter?
Thanks all
Me and my '53!
Thirsty,
Can you post a picture of what you are talking about?
Bread
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
You can see a picture of the part I'm talking about here: Starter Shift Arm
Me and my '53!
Looking at your pictures the flat spots your talking about are very very minor and honestly I would not replace it. I would put a little grease on the whole area when you go back together with it. If you are dead set on replacing I may still have some new ones and will look tomorrow.
Ken
Oh, okay. It was working just fine, so I think you're 100% right.
Thanks for the advice!
Me and my '53!
Well, I replaced the brushes and reassembled it tonight. Everything WAS going great UNTIL I made a critical mistake in testing it... I used jumper cables attached to a 12v motorcycle battery. A quick touch of power proved it was working nicely.
But then I got really dumb... I engaged the gear and ran it for 4 seconds - this seem to get the rpms really high right up until one of the armature wires caught the edge of a magnet bringing it to an abrupt stop. Dang it!
If I trimmed back the broken wire I think I could get it working again - anyone ever done that?
Live and learn - I seem to prefer the hard way of learning.
Me and my '53!
My starter lever was worn to the point of fairly significant flat spots. I simply used my wire feed welder to add material and ground back to round. I then dunk the thing in my zinc electroplating bucket and presto problem solved, good as new.
can you post some pictures of what has happened internally with the starter?
Ken
Here are some pics of the damage at this link
https://skydrive.live.com/?cid=a41da887d3ca75a1#cid=A41DA887D3CA75A1&id=A41DA887D3CA75A1%21265
Anyone think that just trimming the broken wire back might be good enough to clear the way and get it running again?
Thanks!
Me and my '53!
