2 members (Rusty Rod, porsche),
64
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 68 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 68 | Hi, I'm currently rebuilding my starter for my 1953 and I noticed that the arm that engaged the clutch into the fly wheel has several flat spots on it.
I'd like to replace it but I cannot find it at my usual places (Chevs of the 40's, LMC, Ecklers, Jim Carter).
Does anyone know where I can buy a new shift lever arm for my starter?
Thanks all
Me and my '53!
| | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Thirsty, Can you post a picture of what you are talking about?
Bread . | | | | | Joined: Apr 2012 Posts: 68 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 68 | You can see a picture of the part I'm talking about here: Starter Shift Arm Thanks
Me and my '53!
| | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | Looking at your pictures the flat spots your talking about are very very minor and honestly I would not replace it. I would put a little grease on the whole area when you go back together with it. If you are dead set on replacing I may still have some new ones and will look tomorrow. Ken | | | | | Joined: Apr 2012 Posts: 68 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 68 | Oh, okay. It was working just fine, so I think you're 100% right.
Thanks for the advice!
Me and my '53!
| | | | | Joined: Apr 2012 Posts: 68 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 68 | Well, I replaced the brushes and reassembled it tonight. Everything WAS going great UNTIL I made a critical mistake in testing it... I used jumper cables attached to a 12v motorcycle battery. A quick touch of power proved it was working nicely.
But then I got really dumb... I engaged the gear and ran it for 4 seconds - this seem to get the rpms really high right up until one of the armature wires caught the edge of a magnet bringing it to an abrupt stop. Dang it!
If I trimmed back the broken wire I think I could get it working again - anyone ever done that?
Live and learn - I seem to prefer the hard way of learning.
Me and my '53!
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My starter lever was worn to the point of fairly significant flat spots. I simply used my wire feed welder to add material and ground back to round. I then dunk the thing in my zinc electroplating bucket and presto problem solved, good as new. | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | can you post some pictures of what has happened internally with the starter? Ken | | |
