10 members (Shaffer's1950, Cletus1950, Leo, NAPCOStormTrpr, Otto Skorzeny, GDW, MNSmith, Hanks custodian, Peggy M, Hotrod Lincoln),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,139 Posts1,056,455 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99879 03/15/2007 4:19 AM | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Hello,
Do you guys know if the wire harness is similar enough between a 64 and 65 where I could interchange them? Some clown snipped the turn signal wires at the bottom of steering column in the cab i am planning to use.
Any help would be much appreciated.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
#99880 03/15/2007 9:39 PM | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | The schematics in my factory assembly manual seem to show that the connection at the steering column is interchangeable. I am assuming that the wires snipped were those of the turn signal switch. When getting replacements from the junk yard many people do not properly disassemble the steering column to remove them correctly. They end up cutting the connector to remove them. | | |
#99881 03/16/2007 4:42 AM | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Thanks there Rusty64.. I think my harness is sliced before the connector on the harness side. They had a add on turn signal switch wired up to the thing. I have a 65 that i have harvested several parts from so far and hope I can use the wire harness there too.. Thanks again.
