My 52 GMC gauges are the same color as the Chevy but the giveaway that at least the oil pressure gauge is GMC is the 60 lb oil pressure. Another difference is GMC in 52 labeled the cluster surround below the gas gauge as "fuel" not "gasoline" - if you have the surround.
