| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 38 | Does anyone know of a source for OEM style wheels for the '53 3100 with the S10 bolt pattern (5 on 4.75) thanks ralph
Ralph
All gave some - some gave all" -- A veteran is someone who, at one point in his life wrote a check made payable to the United States of America for an amount of "up to and including his life."
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Try wheel vintiques. They have just about any size and style you would ever want. You can even get OEM style hubcaps. http://www.wheelvintiques.com/view-catalogKeystone Automotive has a line of replacement steel wheels at Rockauto.com Try numbers STL01109u or STL00806u for a ralleye style. | | | | | Joined: Jun 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 38 |
Ralph
| | | | | Joined: Jun 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 38 | tons of wheels there confusing I will call tomorrow thanks
Ralph
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I believe what you are going to find is that all the aftermarket wheels are similar. Most have dual lug patterns. In your case it would have 5 x 4 3/4 and 5 x 4 1/2. They are generally called a "smoothy". They are the same as aftermarket "rally" wheels with out the cut outs. The hub cap mounting centers will be smaller than the original but the hub cap can be modified to fit. I got mine from Wheelsmith. Fred
| | | | | Joined: Jun 2007 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 56 | I got mine from The Wheelsmith too, 15x7 5x4.75" (dual bolt pattern), bare smoothies. I bought 5 of those (one for a spare) for $76 w/free shipping. I also bought four new '47 Chevy truck caps for that size wheel for $160. I think it was $540 for 5 wheels and 4 caps delivered. thewheelsmith.net
1947 Chevy 3100 - Shop truck - 250 L6/T5/4.10's 1970 Chevy Camaro - Rotisserie jail
