7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | The Genius who did shade tree mechanic work on my 1951 one ton for previous owner decided to fill it with chassis Lube Grease. Any suggestions on removing it? Is a total tear down needed? Would John Deere Corn Head grease be acceptable to use or is that bad following worse lube for this application? Thanks in advance, Jerry Jerry
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Easy enough to take apart to clean and inspect. Corn head grease is the best option for your steering box.
Bruce | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I dug out what I could from my box with a large flat blade screw driver then added 90 weight gear oil. Everything mixed up nicely over time and the box functions nicely, with no leaks. I adjusted the steering box as per the Manual and was able to find tight spot at the center just like the book says.
| | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Go like Carl suggests, dog out what you can and add liquid lube to it, it will thin down and make a nice combination.
Joe | | |
